tot
- Aug 16, 2007
You should read a bit how S/PDIF works, and this has been covered many times.
But in short, it is not just bits in digital signal. The DAC recovers the clock using leading edges of the bits. However, the edges are not exactly correct and have timing errors. The errors are caused by the senders clock and output circuitry, the cable and the DAC's input circuitry.
Originally Posted by OverlordXenu /img/forum/go_quote.gif How does a cable change the way 10101010101 sounds? Does the $100 cable add more zeros? Does the $20 cable take away ones? Because I don't see how anything outside altering the bit stream is going to make digital cables affect the sound. |
