crazyfrenchman27
- Aug 5, 2004
I'd go for HD555 or HD595 used.
Those two are both very listenable and comfortable.
-Matt
-Matt
Originally Posted by Yellowjacket It can probably supply enough power but its quality is undoubtedly suspect. I'd spring for either the Turtle Beach USB adapter ($25) or M-Audio Transit ($75). |
Originally Posted by kurt_fire So the Turtle Beach USB adaptor will make a significant improvement in the sound my computer outputs? |
Originally Posted by smittysan89 Definately get the MS-1 over the sr60, the MS1 are everything the sr60 is except a little bit better but for about 20$ more... |
Originally Posted by kurt_fire Well, if the MS1 is slightly better than the SR60, how does the MS1 compare to the SR80? |
Originally Posted by Yellowjacket What kind of sound card do you have? For example, the old Soundblast Live! series put out HUGE power. Also, I think a lot of people go crazy over impedances. When I got my HD280's people said "OMG, 64ohm is too much for computer you NEED amp!"... Boy were they ever wrong. Out of my M-Audio Transit (external USB), they are more than loud enough at the lowest notch in Windows volume control. |
Originally Posted by kurt_fire Also, would one of those USB soundcard adaptors really help the sound quality my computer dishes out? My current soundcard is "SoundMax integrated digital audio." |
Originally Posted by mtkversion Sorry I got mixed up and was talking about the 125's I've never used the comfy pads so I can't really compare the 414 pads to them. I can say that the 414 pads are quite comfortable and there is just something funky about black/yellow. I wonder how many headphone geeks at Georgia Tech use the Grado/Senn pad combo? |
Originally Posted by kurt_fire So if most agree that the MS1 is better than the RS-80, I guess that is what I should get. What is the best (also cheapest) online retailer for the MS1? Also, would one of those USB soundcard adaptors really help the sound quality my computer dishes out? My current soundcard is "SoundMax integrated digital audio." |
Originally Posted by kurt_fire These headphones will be used to listen to music (CDs and concert DVDs). I'm looking to spend up to $140 on the best I can buy. The music I listen to is primarily classic rock and jazz/blues, with tidbits of others. I'm looking for something comfortable, and it does NOT need to be noise-cancelling. Also, I do not have a headphone amp, and have no plans to get one. I will just be plugging these headphones into my PC and home theatre receiver. The best pair of headphones I own are some Koss PortaPros. Will something in my budget sound leaps and bounds better than my PortaPros? Which headphones do you guys recommend? Any brand/model is fine with me. I can purchase from an online retailer or even Ebay if need be. I've done some research and seen that Grado and Sennheiser brands are very popular. Which of these is the better maker of headphones for under $140. How do the Sony MDR-V6s compare to Grado SR-60s? Is the difference between the SR-80s and SR-60s worth the $25? Is it worth $50 from the SR-80s to the SR-125s? What other models compare to these for around the same pricerange? |
