rsaavedra
- Jan 20, 2002
Ok I already built a Dynahi. It's not completely finished, but in any case, it's dormant in a storage place. so I don't have a headphone amp with me right now. Very likely I might ship my stuff before end of year, but still the DIY bug is biting my ear again, so I'd like to get my hands dirty on another DIY project. Now here some facts and restrictions:
Fact 1: Don't have my DIY tool set with me. Just bought a soldering iron and a multimeter however. Will buy some other few minimal tools to be able to do the project while all my stuff is still away.
Fact 2: Here in Venezuela the first and so far only electronics store I have visited has absolutely no 1% resistors. Will keep looking, but there might be a provisioning problem there.
Fact 3: edited-out since Mouser ships internationally.
And now some questions.
Question 1: What is the current highest-end DIY portable amp? (Is it the Pimeta?)
Question 2: How much more work or time does building a complete M3 take (power supply included) compared to let's say, building a Pimeta, or the DIY amp that answers question #1?
Question 3: To build an M3 is supposedly much easier than to build a Dynahi. Does building an M3 require doing any not so well documented calibrations or special adjustment after boards are populated? (thinking of the DC offset adjustment for the Dynahi, which required purchasing extra trimpots and waiting another week to get them delivered). Also do I need two multimeters for anything? (thinking of matching transistors for the Dynahi) Or any special tool for any particular requirement?
Question 4: Would you recommend just going easy for now and building a good portable that will use batteries because of the tools and components limitations, skipping the power supply also, or would you suggest just go all the way and build a full M3. Or something else? Possibly, selling the Condor power supplies I'm using for the Dynahi, and building a power supply for it?
Suggestions welcome, thanks much!
Cheers,
Raúl
Cheers,
Raúl
