rsaavedra
- Jan 20, 2002
Final bump before poll closes, in case someone else wants to add their 2 cents.
Originally Posted by diablo9 wow, it's not in tin after all? could you give some more detail about it? where did you find the pic? |
Originally Posted by n_maher Well, I think you made a good choice (ok, choices |
Anyway, enough gushing. Best of luck and be sure to post up some pics when you get the PIMETA done. |
Originally Posted by rsaavedra Anyway, I decided to postpone the M3 idea also after reading a bit the M3 build discussion thread. Some people seem to come across difficulties similar to what I found when building the Dynahi, at least with the DC offset. |
Originally Posted by rsaavedra For now I'll just build and enjoy a portable Pimeta. |
Originally Posted by n_maher Here's a picture to get you motivated |
Originally Posted by rsaavedra Just meant for a newbie the adjustments and debugging could be potentially difficult, that's what I derived from some of the posts in that forum. Maybe it's just the wrong impression I'm deriving anyway. |
Originally Posted by rsaavedra Can't see the image there on your post |
Originally Posted by rsaavedra Nice box, is that a cigar box? Good idea for an enclosure. Also, what is that in the back and left corner inside the box, a linear regulator? (Guessing you are powering this Pimeta with a walwart+the regulator) |
