What’s everyone using for desktop speakers?
- Thread starter big45-70
atarione
- Oct 8, 2016
Speakers you say?? I have some stuff... I honestly prefer speakers to headphones /runs away from angry villagers =p
System 1: Sony TA-N77ES/TA-E77ESD(200wpc) (etc..sony ES components) > Yamaha NS-344 (10" 3 ways)
System 2: Kenwood KR-V016R (100wpc)> JBL L1
System 3: Pioneer SX-3600 > NHT Super Zero's + NHT SW1
cwall64
- Feb 2, 2010
Out of curiousity, I have a Schiit Jot running XLR pre out to a JBL LSR310S then to JBL 305P MKII - should I run low gain when in this config with the active monitors?
silverbot01
Yes you should be running low gain. Low gain will take whatever you are giving the Jot (2volts RMS from the internal dac/4volts RMS usually from a external dac) and double that for the maximum voltage on the pre. If you apply a higher gain setting it'll give you less room on the volume knob and possibly more noise due to gain. If you ever find yourself turning the knob all the way then maybe the next gain setting would be of use, otherwise just stick with low. (2v x2 from internal (4V) would be the usual maximum on an XLR pre and I have no reason to believe the JBLs would ever need more).
bilzebub
- Dec 19, 2009
Emotiva AirMotiv4 near field monitors. Reccomended by CNet's Steve Gutenburg (https://www.cnet.com/news/emotivas-astonishing-desktop-speaker/), and they aren't bad at all. Though I think he has since found ones he likes more.
MisterMudd
Have had the same speakers for about 3 years and they totally rock. Haven't had the urge to upgrade yet, though I know there are better speakers out there. Yeah, I bought them off of Steve's recommendation.Emotiva AirMotiv4 near field monitors. Reccomended by CNet's Steve Gutenburg (https://www.cnet.com/news/emotivas-astonishing-desktop-speaker/), and they aren't bad at all. Though I think he has since found ones he likes more.
petersh
I have Aperion Allaire and it has been good. I don't need a big bass speaker, but it should be clear sound
"Persistence can change failure into extraordinary achievement", Find You Lazada Voucher COde at Muarehon
A pair of JBL LSR305's for my PC video and gaming and a pair of JBL LSR308's gathering dust (if anyone is interested)...since they turned out to be too big for the room I was using.
Cheers!
-HK sends
Cheers!
-HK sends
baiyy1986
My JBL LSR 305 also does a great job of gathering dust.
Worth the money.
Worth the money.
I'm running a SB Zxr out to a Kenwood KA-7300 then to KEF Q350s. Love the dual mono of the 7300 and the KEFs are just ridiculously good for the $. (Present from dad for birthday last year)
groovyd
- Jun 29, 2012
Magnepan Maggie Minis via PrimaLuna DiaLogue via McIntosh D100 via JRiver via MacBook Pro
Nautrachkfriend
I'd love to see a picture of that setup!Magnepan Maggie Minis via PrimaLuna DiaLogue via McIntosh D100 via JRiver via MacBook Pro
germanium
I run a set of modified JBL LSR305's along with a modified Tannoy TS10's driven off a modified Asus Strix Raid DLX.
groovyd
- Jun 29, 2012
oh, almost forgot the 20.7s
