TEDW
- Feb 8, 2007
Wash your eartip. Clean the nozle. Slippery because of your body oil.
Can anyone comment about the bass of the W80? Is it elevated, or in line with the rest of the frequency? The reason I like the W30 better than the W40 or W60 is the slightly elevated bass and treble. I find the other W's a bit boring. I'd really like to see frequency graphs of the entire line.
They are incredibly small earpieces. I'd like to see how they look inside. They're by far the most comfortable IEMs I've tried, including customs.
Has anyone heard W80 with Hugo or Mojo?
So I assume like any responsible head-fier you took a day off, feeling "under weather" to wait for your W80 delivery?
Hi, I new in this forum. I currently own W40 and Noble 6, and I do have a slight issue with W40 where the star tips keep falling out and struck in my ear or drop to the ground whenever I remove it from my ear. Does any of Westone user experience or encounter this on W80? I do like the W80 however just worry will have a similar encounter which hold me back from making the purchase.
So, if I am in for a warm sound with good bass (like my Westone ES5), W80 seems NOT the way to go? Should I get W60 instead to get similar sound to my ES5?
Curious I have a moon audio silver dragon cable with my W60 can you tell me how it is compared to the W80? with stock and ref8 cable
In the past I have tested W60 with TWag v3, another silver cable, and in my opinion such pair up refines the sound, sharpens the details, but it won't drastically change (and it shouldn't) the Frequency Response of the tuning. I actually have W60 paired up nicely with Linum BaX cable, it's SPC and not a pure silver, but still gives a similar sound improvement as a pure silver cable. Cable doesn't affect the sound as drastic as EQ, especially when you are dealing with a laid back smooth tuned IEM like W60. So in my opinion, W80, especially with Ref8 cable, has an advantage in sound tuning over W60 with a silver cable.
You might be one of the few that like the W50's
I've never heard the W50s.
W30s are my favourite of the W** line up.
