xaddictionx
- Jan 18, 2013
Haha sound is very subjective. Surprisingly the Bose IE2 ain't that bad.
Yes not bad but definitely another league... he said Weston has no bass! LOL
I think he should head over to T-Peos H300. A hell of a bass..
Westone focuses more on mid bass..
I am curious what kind of source or setup you are using when you tried the Pro 50. "Rubbish" is a very "strong" wordI would say the pro 50s are not that bad at any aspect.
But I had an experience that was quite similar to what you said. I made a mistake when I was connecting from my player (fiio x5) to amp (fiio e12) using the "speaker out" instead of "line out".
That sounds really bad~~~and that is what you had described.
Actually, pro 50s sounds great even if you just directly connect it to a iphone 5.
But I am sure everyone has their own taste. For example, i do think "Astell & Kern" 180 (not sure if i remember their name correctly) player is not good at all. The sound is thin and not natural at all. However, I am sure some ppl like them. And, that is absolutely fine.
Nano is really not a good source. IMO, Nano is only better than the shuffle in the apple player family.
I think the reason for that "ugly"sound signature was caused by the source. It looks the nano was unable to drive it well.
You may try it another time with a iphone 4s or 5 or.... I bet the um pro 50 would be different for you.
Yes, I love the bass of shure 846 better than that of the pro 50.
Btw, do you enjoy the w60?
Has anyone tried musicfx on android?
For the um 30 pro
http://imgur.com/PC74rCH
http://imgur.com/iwWIxM9
For the um 30 pro
You should give Poweramp a try on Android, using that on an LG Pro G with the UM-Pro 50.
Couldn't be happier
