coolhand
- Jun 21, 2008
I have to say as bass iems they sure dont compare to the less expensive ckr10 or ath-e70. I think Westone could do better in this department. It's really hard trying to tolerate the bass after listening to Audio Technica even though im a fan of um pro 50.
Well there you go.. as I mentioned previously, there's just no accounting for personal taste !
As yet I haven't heard the ath-e70 so I can't offer an opinion regarding their sound, but find the UMPro 50 to deliver sublimely rendered subterranean bass performance when driven from the Chord Hugo for example. In my ears I prefer the largest size Star Tips for absolute bass power or alternatively Shure Olives for a tad less lower end balance, tried SpinFits and although very comfortable they're made from a thinner silicone which provides a less rigid seal and as such I found bass rolled off much more than I prefer.
Conversely to your take on the ath-e70 bass performance, I found this review of them online:
http://www.churchproduction.com/story/main/first-look-audio-technica-ath-e70-professional-in-ear-monitor
Upon fitting the ATH-E70 monitors and listening to some standard recorded material, my immediate thought was that they are very bright. This may be exactly what the designers wanted for cutting through boomy or muddy stage wash, but it is quite pronounced.
Because of this powerful mid- and upper-frequency response, I would see the ATH-E70 as ideal for singers, guitar players, or even drummers, with one potentially important caveat. More on that later. One would not miss the slightest nuance or detail when monitoring mids and highs with the ATH-E70. The clarity that they reveal in the bowed string on a violin is uncanny, not to mention how they reproduce cymbals. I’ve never heard cymbals sparkle like they do with the ATH-E70. Playing back music I’ve listened to for years revealed details I had missed with other monitoring systems.
On the other end of the spectrum, the ATH-E70’s bass response sounds suppressed. It’s as if everything below 150 Hz has been rolled off with a high-pass filter. This may be to protect the drivers for longevity, or perhaps to install a greater sense of mid-range clarity. I think the explanation is simply that the ATH-E70, like most universal-fit ear buds, has a rather weak low-frequency response. That’s not to say that you can’t dial in all the lows you want with EQ, they just don’t naturally reproduce the lows the way custom-molded ear buds do. As stated above, if you’re a singer, a guitarist, or a drummer who can do without hearing a lot of kick drum or the low end of the bass guitar, the ATH-E70 sounds excellent. If you want to shore up the low frequencies, you’ll need to add EQ.
