Westone ES uses a thicker gauge pin, it WILL work, you just gotta butt**** your TF10 with it and it will stretch the holes out so that you permanently converted your TF10 to Westone ES.
The regular Westone cables are compatible but you want to clip or file the pins down to about the same length.
