I like using this amp with the Lambda Pro and HE60: https://www.parts-express.com/lepai-lp-2024a-2x15w-tripath-ta2024-hi-fi-audio-stereo-power-amplifier-with-3a-power-suppl--310-296
No, most dynamic headphone amps will not have have enough power. Woo Audio suggests using the Wee with amps that are rated at least 3W of power (they don't say into what load, but I would guess 8-ohm). You may want an even more powerful amp depending on what earspeakers you are driving and how loud you want them.
I have a Bryston 2BLP which is 100W power amp. I was speaking more in line with a Jotunheim for something with a similiar power rating. Someone who wanted to buy mine was asking me about using a headphone amp (a Cavalli Audio Carbon)
Yes, you can use the Woo Wee with VTL or Krell, but given the high power of these Amplifiers, you will need to be careful with the volume potentiometer of your preamplifier, so as not to damage the Stax Headphones, connected to the Wee.
I use a Woo WEE for several years with Drivers with 300B and 845 Valves with my Stax Omega 007-MKII, and I have never had any kind of anomaly and / or operation.
Reading the article, it seems to me that the problem has been with the 009, which have New Transducers, thinner than my 007, and maybe this can cause probable problems ?? The other Stax L-700, which has transducers similar to 009, I use with a HeadAmp KGSS C.E., and I am very pleased with the Set Up.
Just got a pair of STAX L500s used. I have an Audiomat Arpege for a speaker amp and was thinking of trying the Wee to run the L500s of the Arpege. Anyone have any idea if that is safe to do or not? My research is indicating yes, but just want a final confirmation (as if the Arpege was damaged I would lose my mind).
Realizing this thread has been inactive for a while, hopefully someone can reply... I'm looking for a good amp to match my HE-60 and finding that it's 540v required bias doesn't play nice with my Mjolnir Carbon, though supposed it should work with 580v amps as well. So I'm wondering if anye here has had success, or know of people that found good success, pairing the WEE with HE-60?
Thanks so much for any insight..
