Triode User
Member of the Trade: WAVE High Fidelity
just bought a Qutest and tried it in my secondary system
looks this amp (RWA Signature 15) doesn't like 3v line in as all is fine as soon as I set Qutest line out to 2v
plan was to replace the 2Qute in my main system with the Qutest and move the 2Qute to my secondary one
question: anything I can do ("easily": might consider some simple DIY) to lower 2Qute's line out voltage, please?
The Qutest has switchable line out voltages exactly so you can select the one that is appropriate for your amplifier. If the 2V line out from Qutest works fine then there is no problem to be solved unless I am missing something?
