Improve your DAVE and Wideband combo!
Our BlueDAVE connected directly into our widebanders, Omega, Voxativ and others is a very special team. We enjoy the directness, soundstage, purity of sound and more, even if others still belief, that our 2 watts cannot rock!
I did not think that I could improve them again, but it is now a reality, I have successfully done it. No, it is not my idea, the basics are well known, even nobody seems to apply it. You can try it as well; I will show you the simple experiment. There is a reason that I am writing this here, because when Mr. Watts and Mr. Franks were interested, we would have a very special power Dac soon.
Being a voice coil, an ignition coil or a crossover coil, all coils are current devices, should be driven with current, but all our amplifiers are voltage items, the only exception were the First Watt F1 and F2 by Nelson Pass. This is just for convenience, because when ordinary speakers are driven by current, they respond unpredictably, but it is possible to solve this.
So the speaker always fights against the incoming voltage, must convert it into current.
Now the experiment: Probably you still have the amplifier that you removed from the chain, when you noticed, that it is much better without it. It should be a solid state, 50 Watt+.
At first you check it, I always bring it up with a variac and measure dc, when they had been tucked away for a long time. Then you connect it to Dave and speakers, but you connect a series power resistor between +out and +cable, 10 Watt is enough. This converts your amp a bit into a current amp. The resistor should not be too high at first, not more than 5x speaker impedance, I took 20 Ohm, because I drive my bipolar Omegas parallel, 4 Ohm. For 8 Ohm take about 40 Ohm. There are 2 side effects with this arrangement, because the speaker follows now its impedance: Bass will be louder but worse, not controlled very well, and the highs could be louder, but this can be solved later. Now listen for a few hours, not too loudly, because bass is a bit out of tune. I was lucky with the Omegas. Highs were a bit harsh, but just for an hour, so it must have been something else, and the Omegas have a flat impedance curve there.
To tame the bass, I tried the solution Nelson Pass has given for different drivers. A parallel resistor across the speaker terminal flattens the impedance curve, for Omega single Alnicos start with 30 Ohms, and try different values. By the way, the flagship Omegas are inappropriate, because there is a crossover coil. But with the help of Louis it will be possible. When bass is O.K. again, you can try a higher value for the series resistor, I went up to 40, and decided then to stay with 33 Ohms.
Results: Soundstage opens even more, there is more background information, there is more speed, dynamic and tenderness at the same time. The speakers seem to be happier! This is remarkable, because:
- There is another amp in the chain again, and we remember us saying, less is more!
- I listen now to the same amp again, that I removed months ago!
The explanation: Joe Rasmussen has measured a chassis with current and voltage drive. The distortion values were up to 10db lower with current drive!
Our experiment is not elegant, a lot of power is wasted in the resistor, but for the technically minded, it is possible to convert a voltage amp into a current one, so the output impedance will be even higher, but Nelson Pass told, that there is no need for very high values.
In the future, there is only one possibility to improve this amp:
When the new power dac would have a possibility to convert it into a current amp, we would have an even better solution. Thank you!
Otherwise it makes no sense for me to buy another voltage amp. There is no return!
