Don't be so hard on CHORD.No analog inputs as the technology operates on dac itself, it's the same as output from current chord dac lineup but with higher power.
In this case analog inputs would need to be digitized which doesn't make sense i believe.
Bob Stuart (Mr. Watts favourite engineer) of Meridian Audio, even included the loudspeaker to the set (DAC+Xovers+Amps+Loudspeakers) back in the late eighties I believe!
Once you aim for ultimate sound quality, analogue, BT or phonographs etc. will have no place in the chain.
I suppose Mr. Watts could include Wifi with his upcoming creation, to do away with physical connection once and for all.
No electrical noise, Asynchronous buffered input, best of all worlds.
Mono-block?
well that would be something to consider . . .
