miketlse
- May 8, 2016
RF cannot travel through optical fiber. There is no ground in an optical fiber. It does not connect the grounds at either end. Or make any electrical connection. There is however a ground in USB and RCA s/pdif, so they can both form a ground loop if the equipment at both ends is connected to earth. I think Rob uses USB and therefore likes to run his laptop from batteries so the laptop isn’t earthed or connected to neutral.I guess you know the answer because Rob has spelled it out many times and hence why I don’t need to suppose. It travels in the ground plane and hence why he uses his laptop in battery mode rather than with the mains charger plugged in.
@Rob Watts please tell me if I should eat humble pie and admit I am wrong in what I just said.
Oh not again please.......................RF cannot travel through optical fiber. There is no ground in an optical fiber. It does not connect the grounds at either end. Or make any electrical connection. There is however a ground in USB and RCA s/pdif, so they can both form a ground loop if the equipment at both ends is connected to earth. I think Rob uses USB and therefore likes to run his laptop from batteries so the laptop isn’t earthed or connected to neutral.
Surely someone who sells £1400 cables should have a clue about how cables work.
I've got to admit, when I read about ground noise over an optical fibre I had to double-check nobody had spiked my coffee with drugs.Oh not again please.......................
@Amberlamps grab some too.
Yes but that was with USB connection. Optical can't create ground plane noise from the source ground. However, in principal it could inject a small amount of ground currents into the ground plane from the amplifier built into the optical receiver device. But this is ultra small scale stuff; but I do put ferrite beads and RF filters on the optical receiver just in case it might have an effect. But noise from the source will be eliminated with optical, as the noise from the optical amplifier in the receiver would be SPDIF only related noise. You still have the possibility that the source will inject processing related noise into ground and the mains, and then being picked up inside the DAC from ground loops, but again this is very much a theoretical possibility - it needs intersecting ground loops to create an effect so that the DAC will "see" the noise - and this is certainly not an issue if the DAC has optical inputs only, and no other ground connections on the analogue side (listening only via headphones directly for example).I guess you know the answer because Rob has spelled it out many times and hence why I don’t need to suppose. It travels in the ground plane and hence why he uses his laptop in battery mode rather than with the mains charger plugged in.
Optical is... light.... Ground currents don't normally travel via light...
So what could be causing the Optical 1 which is directly from the motherboard to exhibit that hissing noise at max volume and Optical 2 not to?
Depends how you interpret that conclusion?
You know people buy and then sell Dave for the same reason?
Nice to know, yet again, we can always count on you to do the right thing. Thanks!... I do put ferrite beads and RF filters on the optical receiver just in case it might have an effect...
So, are you saying that if the DAC (the HMS/TT2 combo in my case) is only using the optical inputs (despite having the other inputs available), and you are only using headphones, then even this theoretical possibility is null?... You still have the possibility that the source will inject processing related noise into ground and the mains, and then being picked up inside the DAC from ground loops, but again this is very much a theoretical possibility - it needs intersecting ground loops to create an effect so that the DAC will "see" the noise - and this is certainly not an issue if the DAC has optical inputs only, and no other ground connections on the analogue side (listening only via headphones directly for example).
