Ards
- Jul 22, 2010
I have x2 AVAA's in the front corners behind my main speakers and subs. Whilst they help, they are expensive and not as good as I expected. Perhaps another x2 might work better but I thought I would try convolution instead. I use them now with the convolution filters as there were other issues with my speaker's upper range that needed "taming"! I don't have magic ears so can't detect any major loss in depth/transparency but the sound is now less fatiguing and more balanced.
My Utopias are still very enjoyable direct from DAVE when I can't run the main rig; as long as I remember to switch off the filters!
The AVAA’s do take careful positioning - you need to measure the room and identify the major nodes you want to target and place them in those locations. The before/after results are clearly measurable eg in REW and the listening result in the room is that they help tame bass boom and ringing caused by the standing waves. It’s one of those affects you most notice after living with them for a while and then turning them off: the sound is coloured without them.
