Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
It depends upon the DAC - Dave requires sync, so length is important, but all the other DACs use the AES3 dual data flag so don't require exact sync.
The reason I was doing this listening test was the Hugo 2 HF filter gently rolls off at 20kHz - it's about -1dB down. One reviewer commented that this was the reason for it sounding warmer, and I thought that was unlikely - although it's possible. The new filter actually has 20kHz compensation built in, and nett boosts 20k by +0.4dB (to compensate for other filters). But even with this boost, it still sounds warmer, proving that noise floor modulation is the cause of the HF filters change in sound quality.
The issue of RF noise, and noise floor modulation and how sensitive we are to this problem came to the fore a couple of days ago. I am working on several new projects, and one of them I was doing listening tests on a new HF filter - like the one in Hugo 2 (the white to green filter). Now this filter with 44.1 is technically minute, as HF noise is extremely small when using CD. But I could hear a difference, albeit small. So I ran a single blind test with my son, and asked him to state which one sounded warmer, or if they sounded the same. He could spot the HF filter, identifying it as warmer sounding - although he confirmed it was a small change.
