just when you think you have seen everything, comes this extreme built as an
extreme. At least it was an extreme designed board in a MPX3 chassis.
Now i knew this one was going to be real trouble when i first saw pictures of it.
I open the thing, turn it on, no filament power, but the .15 ohm resistor while
very toasted is still conductive. But it fell right off the circuit board.
http://gilmore.chem.northwestern.edu/raffy4.jpg
So its obviously time to remove the circuit board.
But wait, the side board is soldered in from the backside
http://gilmore.chem.northwestern.edu/raffy8.jpg
http://gilmore.chem.northwestern.edu/raffy6.jpg
http://gilmore.chem.northwestern.edu/raffy5.jpg
and no way to unsolder it without brute force.
Sweet.
3 hours later...
http://gilmore.chem.northwestern.edu/raffy1.jpg
The resistor burned all the way thru the mounting pad on the left.
but did you notice the soldering job...
here is a closeup
http://gilmore.chem.northwestern.edu/raffy3.jpg
globs of solder just barely hanging on the board...
Finally 20 watts of resistor on ceramic standoff's that
should live a while.
http://gilmore.chem.northwestern.edu/raffy7.jpg
OK, further comments, it was obvious by the time this was built that
lots of the smaller transformers were burning up, so mikhail scaled up
the transformer. He scaled it up a bunch. 7.5 volts AC before the diode
bridge under load. So the diode bridge gets even hotter than the previous
units, and that poor little original 5 watt resistor is running at right around
10 watts, and still delivering only 5.8 VDC to the tubes.
my 5 watt x 4 resistors in parallel end up .125 ohm, and generate about
12 watts of heat.
Bottom line, every one of the units like this is going to do the same thing.
While the parts are cheaper, the labor is 4 times that of the other units.
If you own one of these versions you should open it up and take a look.
