i used the same method i'm using with the other DAPs.
@Samueru Sama taught me, and i'm getting very approximated impedance for every DAP i'm measuring.
first i measure the Vrms at some volume (i use to choose from 1Vrms to 2Vrms, around 1.5Vrms in this case), with no load, using a tested digital multimeter..
then, at same volume, i add a known resistance in parallel (voltage divisor), and measure the fallen Vrms, using the multimeter.
this way you can estimate the output impedance being used.
still not 100% accurate because i'm waiting for some electronic gear, but, if I didn't make a big error (which is always possible), the output impedance is around 100Ω.
about line-out output impedance, 2KΩ is the lowest i got..
it is crazy, i know; i must be missing something..
anyway, the roll-offs are there, measured directly from walnut to my soundcard line-in; and Pai Audio MR3 (critical sensitive multi-BA iem) sound really horrible with the walnut.
