Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
Discussion in 'Portable Source Gear' started by vapman, Dec 8, 2016.
161 162 163 164 165 166 167 168 169 170
172 173 174 175 176 177 178 179 180 181
  1. endia
    that makes sense! thanks a lot..
  2. heraleks
    But bypassing opamp is more efficient :) I use in both places.
    [​IMG]
  3. endia
    will do both, thanks a lot..
    does it 22uF too or 0.1uF? i used to 0.1 uF mkt/mkp for opamp bypassing..
  4. Byfrost
    Curious question...
    Does anyone have pictures or link me to a thread in relation to the Walnut "V1" of this player. I'm curious to read up and find out more on the very first V1 Walnut information.
    The only information I read is it has 2 volume knobs that's about it.
  5. heraleks
    it's 22uF
  6. peter123
    I ended up ordering a second Walnut to use as a dedicated amp. Hopefully this functionality will work properly on the new one.
    It will also make comparing op amps a whole lot more reliable by having two players.....
  7. Abdi
    Koss KSC75+Walnut v2 is really a hard drug :) They really do sound fantastic to me :)
    Podster likes this.
  8. barbazz
    Got My Walnut yesterday. It seems to be a hard drug with a number of different earbuds [​IMG]
    So far Qian 39 (with Wim Mertens) and Boarseman K25S (with Deine Lakaien) are killer combos. Trying Monk+ with Mad Max OST as I write. It's going to be a fun weekend [​IMG]
    Abdi likes this.
  9. Dark Helmet
    I did this mod.  Thank you I can actually op amp roll and use my Rubycon 1000uf 16v cap with out noise on the op amps.
  10. Dark Helmet
    By the way Grado SR 80E sound awesome with the Nut.
  11. groucho69
    Do you get odd looks too when you speak of rolling your nut?
  12. Dark Helmet
    All the time.  [​IMG]
  13. groucho69
    I always limp away and let them stare.
  14. heraleks
    LOL I can say to myself RTFM, because in the datasheets on the opamp there are recommendations for bypassing. For example, for lm6172, 0.01 μF ceramic and 2.2 μF tantalum capacitors are recommended from V+ and V- to GND. In our case, V- is GND, so you can simply increase their capacity.
    [​IMG]
  15. ER4S
    It's also great with ER4S. Of course something always missing but 'nut drives it like authority.
