vapman
Member of the Trade: bhobuds.com
- Aug 14, 2006
Hi, I have one of these babies and am mostly loving the sound quality. I am mostly converting CDs to WAV using Foobar but I am still getting problems after at least 30 to 40 hours of use - I get a regular faint click noise, like a scratch on a record, after playing a few minutes. At first it continued for about 15 minutes then went away but now it goes on for at least my commute to work - an hour.
I have read they need running in and issues like this go away, how long is this running in period?
Out of interest can anyone explain why they need to be 'run in' and what this actually does? I don't really understand why modern electronic components would need running in but that may be my ignorance!
Cheers
If your walnut does not have at least 20-30 hours on it then i would keep waiting.
I've had something like 5 Walnuts (2 of them i gave away) and on each of them i got an occasional pop or click like you describe until teh 20-30 hour mark. then it goes away completely.
Some of them i just let it play into some headphones for two full battery charges, by that point its about 40ish hours on it, and they all sound prfect...
Honestly i attribute the pops and clicks and such to the electronic components settling. The walnut is assembled from fresh parts and only tested very quickly, so it's not like a more expensive player which might have enough testing at the factory pre-shipping to remove these glitches of very fresh parts?
