Walnut Hi-Fi V2 WAV (& MP3) Player by wt - :ok_hand: screenless budget killer combo DAP/Amp :ok_hand:
Feb 6, 2017 at 6:46 PM Post #1,878 of 3,634
  Walnut for sale in forums.
http://www.head-fi.org/t/834595/walnut-v2-player-incl-various-opamps
​I am trying to get it! I guess we will see if I was fast enough.
Thanks for the heads up, I got it!
Now I won't have to wait a month and I get some opamps to try!!!
Feb 6, 2017 at 9:33 PM Post #1,880 of 3,634
Feb 6, 2017 at 9:34 PM Post #1,881 of 3,634
Question I am trying to shuffle my files I have sorted them out into folders but I want to be able to shuffle the folders so I don't have to listen to the same order all the time.  what is the easiest way to do this.  I am running on a Mac.
Feb 6, 2017 at 9:37 PM Post #1,882 of 3,634
As someone new to this Walnut thing, how does one go about purchasing opamps easily? Do I literally just try eBay or something?
For us Aussies RS Online is the best outlet, free express shipping, and legitimate parts. There so many other good choices besides NJM5532 though, which are $1 each in packs of 5:
http://au.rs-online.com/web/p/operational-amplifiers/3137795/
Feb 6, 2017 at 9:39 PM Post #1,883 of 3,634
Find my post here, it might be helpful. Unfortunately I have no idea if it will work on Macs :(
Feb 6, 2017 at 10:12 PM Post #1,884 of 3,634
That's the cool part about this player.  Lots of op amps to tailor to your personal sound signature.  I still have a few op amps on the way to try.
Feb 7, 2017 at 1:15 AM Post #1,885 of 3,634
  Just installed a JRC5532 in my Walnut.  So much better sounding than the TI5532.  Better texture, soundstage, depth, and speed.
I concur about all non ti branded 5532's i have tried to date. JRC4556 i can also easily recommend to fans of the low end and powerful sound. I have tried some vintage 5532 that were very delicate and $  but i find the 4556 to be at least as good and actually near identical...
Feb 7, 2017 at 4:10 AM Post #1,887 of 3,634
Hi all! I have been reading the thread, and it got me quite interested in this small gem! I currently have a DX90, will the Walnut work better as a standalone DAP, or could it function well to pair with the DX90 as well?
Feb 7, 2017 at 4:14 AM Post #1,888 of 3,634
You could use it as an amp! But it can be kind of hit or miss depending on source or opamp config. it is usually good.
dx90 specs: Output Level: 1.3Vrms(Low gain), 2.0Vrms(Mid gain), 2.8Vrms(High Gain)
so if you need it to get louder...
Feb 7, 2017 at 4:20 AM Post #1,889 of 3,634
I see, I solely use IEMs and earbuds, so even on my DX90, I alternate between low and mid gain, and usually just slightly over half of the volume. So I doubt I will be needing it just for boosting volume. But in terms of being a DAP? How does it compare against the DX90?
Feb 7, 2017 at 4:22 AM Post #1,890 of 3,634
I wish I could tell you. I have never so much as seen an ibasso device. I think some others here might be able to help.
