I made a comparison of them a while ago, so maybe that could help you decide:
So I got my GR07 Classic and it sounds pretty similar out of the box to GR07BE. Guess that was just brain-in after all? :tongue_smile:
At any rate, the Classic is definitely less bassy (shock) and the bass register sounds cleaner. BE has louder bass, but not necessarily deeper. Mids are more forward and neutral than the BE. Treble honestly sounds about the same. There's a bit of sibilance and offensive snare drum here and there, but not much worse than the BE. Maybe these are more in line with the MKII? I dunno, just describing it as I hear it. If I had to personify these, they're like brother (BE) and sister (CE), where one is a bit more powerful and the other a bit more elegant, but clearly cut from the same cloth.
I really love the way things like Progressive Rock/Metal, Classic Rock, Vocal Pop, Jazz, and Classical sound on the Classics compared to the BE. That said, Bassier EDM or Pop, Hip hop, and newer Metal might be better suited to the BE. I'm sure all of this sounds like common sense, but it's always good to test your assumptions. At first the Classic felt a little soulless and cold, but listening for a half hour or so changed that right up.
Both are great phones, both have the same general sound signature and feel to them. CE is cleaner in the bass and mids and BE is fuller and warmer. If you're on the fence about which is right for you, just look at your music preferences, and don't think about it more than that. If you value clarity and an unmuddled sound, go for the CE. If you want to feel that bass impact and willing sacrifice a bit of clarity (still plenty of detail, just a hair tad muddier), BE is your guy. "
Hope that helps.
