jmills8
Previously known as bmiamihk, jmills2
If anybody is interested Im putting my Duo amp for sale. I just bought it and I havnt even charged it.
For those who use the Pure 2+, would using the Mojo be an improvement over this? Since I already have a very low impedance headphone (TH900), the amp doesn't do a whole lot for it. My use is primarily listening music from a laptop, hence why I prefer one or the other.
I've hardware tested the pair. Under stress of load, PURE II performs a bit better than an unmodified Mojo regarding stereo separation, and a few other benchmarks, but that assumes it is being fed a signal as good as Mojo can spit. PURE II is about as good a portable amp exists - this includes actual metric performance. Mojo beats it with regards to THD and IMD, but at typical listening volumes the two are on par.
The problem is feeding the PURE II with a signal the equal of its circuit, which is phenomenal. For this reason, I heartily recommend pairing the two for best absolute performance. I've measured the PURE II at 119dB SNR, which is about the limits of what Mojo can output. That's almost unheard of.
mmm....intensely curious: what headphones have you tried with the MoVo stack and sounded phenomenal?
Hey all, maybe someone can give me some input.
I ordered the Pure II + a week or so ago.
Ive only just noticed that the revised DUO seems to be designed more for IEMS and am thinking I may have made a bit of a mistake with my order, and should has purcahsed the DUO instead...
I will be using Noble K10u with it.
Will there be much of a difference between the revised DUO and the Pure II+?
Thanks.
It has a bass boost and treble boost and also states;
'revisions specially designed for the sensitive IEMS to higher-range impedance Earphones'
Maybe its just the impression im getting, but to me the product blurb is making it seem more for IEMS.
http://vorzuge.com/product/vorzampduo/
Really unsure if ive made a bit of a silly mistake with my order.
If you need bass boost and/or treble boost then yes you probably made a mistake.
However the II+ is virtually silent with any IEM I have heard it with so in that respect I wouldn't worry about it at all. It is also extremely clean and rather powerful so you can drive from it fairly power hungry cans making it very flexible.
