The resistors from Rapid are made by BC Components, whose parent company is Philips. The VDs are just a step up from generic resistors, same as the ones available in the in the UK. The price is similar to domestically available resistors of the same grade, even though that's no real indicator. If you want to go a real step up, if you can get some of the Holco resistors they are better, however they don't fit the usual R207 profile, and are considerably more expensive.
Before you claim "bragging rights" I suggest listening to what you can get first, and then if you're not satisfied you can import some "approved" resistors. I think you'll be disappointed.
