baxter_nst
- Feb 26, 2009
From MySpace:
June7
I put Magix levitation feet under the computer case and PSU, I could still hear the difference with HD590 but it wasn't as huge as with K1000 because normal headphones have reflections inside the pads which mess up the midrange resolution. K1000 has flat and neutral sound, and Magix keeps everything flat while increasing the resolution from top to bottom. Magix + K1000 is a perfect match.
When I was untweaking my K1000 system, I removed the Genesis power cables first, then I removed the Magix levitation feet. The tweak that gave me the most for the money was Magix. But when I tweak my HD590 system, Genesis power cable gives me the most for the money. For HD590, the improvement from Genesis is 10+ times bigger than Magix. I believe that Genesis is a component upgrade that even non-audiophiles can hear. It makes the bass bigger and tighter, how can people not hear it? I'm really considering selling my entire K1000 setup to buy a custom Judge power cable ($25k) to plug into my computer and use HD590 from EMU0404 soundcard. That's how good Genesis is.
June7
