pompon
- Dec 25, 2006
Ty Nalth. It's seem it's not blocking only a tiny range (my friend was telling me that ... I guess they was worng).
Originally Posted by Ragonix /img/forum/go_quote.gif How can the Genesis 1.1 PC possibly be the best value when it costs 6.7k. Did VD give Patrick a free cable so he would say all these things? |
Originally Posted by Patrick82 /img/forum/go_quote.gif I rather have computer + Genesis than a high-end transport + stock cable. |
Originally Posted by Patrick82 /img/forum/go_quote.gif I'm using HD590 + EMU0404 soundcard now, no tweaks or anything. I have compared stock power cable against Genesis. The difference was HUGE! |
Originally Posted by Patrick82 /img/forum/go_quote.gif K1000 have rolled off frequency extremes and it took a couple days to get used to HD590. I'm not getting fatigue when using Genesis power cable with HD590 anymore. I'm still shocked how good HD590 sound when plugged into a computer driven by Genesis power cord! I don't miss my K1000 setup anymore! Stock: Thin and veiled bass. Bass information is lacking. Highs are very sibilant and harsh, there is no high frequency information, it's just bright. There is no transparency because of too much brightness. Everything is flat and 2 dimensional, there is no depth or ambient information. Everything is compressed and lifeless, there is no layering. Genesis: HUGE bass that is very tight, there are more bass transients in deeper layers. The highs are smooth and transparent, there is no sibilance!! The brightness in the highs has transformed into detail! There is a lot of information there! There is more layering and ambient sounds which makes the soundstage sound bigger! It sounds very musical and I want to keep listening for hours! Genesis power cord transformed HD590 into something very good. Normally HD590 are boomy and sibilant, but Genesis removed the sibilance and tightened up the boomy bass while making the bass even bigger! It also increased the resolution and everything else as well. I didn't think HD590 could sound this good. |
Originally Posted by tourmaline /img/forum/go_quote.gif Instead of buying such expensive cables, why don't you try different materials yourself? By the way i do know that good powercables make quite a difference! I experimented myself extensively with all kinds of cables. More then 6000 dollars is alot. |
Originally Posted by Patrick82 /img/forum/go_quote.gif I have discovered that different materials only change the flavor of the sound, I got the most neutral sound from a stock cable. It had more low-level detail than Nordost Valhalla but it was harsh and fatiguing. Valhalla veiled everything which made it sound smooth, thin, open and musical. I think the reason Valhalla sounded so veiled was because of the threads wrapped around the conductor which made the conductor vibrate more easily. More vibration of the conductor results in less low-level detail. Genesis has crappy copper wiring inside but loads of vibration dampening around the conductor. The improvement in low-level detail is huge, and it's easy to hear even with HD590. I'm still shocked that HD590 + EMU0404 can show the difference! I get the best sound when I don't have any pre-amps, amps or interconnects. Plugging the headphones directly into the soundcard or DAC gives the best sound, as long as the measured performance is good. When I plugged my K1000 into the default 2vrms XLR output it was worse than all amps I have tried, but when I used the 6vrms XLR output it was better than all amps even with loads of tweaks for the amps! Running headphones directly from the source with no external pre-amp and amp is the way to go, even without Genesis power cable. I noticed that external pre-amp and amp combinations only changed the flavor of the sound, it either made it appear more detailed because the bass was gone, or it made it more bassy because the highs and mids were toned down. I don't see the point of reducing the volume with the pre-amp only to boost it back up with the amp. Plugging the headphones to XLR or RCA outputs gives me more neutral sound and higher performance. I think Genesis power cable makes all dedicated headphone components obsolete. A single box system with a vibration dampened power cable is the future. It's simple and cheap. But the only "problem" is that you can't get any flavors from it, it will just be neutral. But you could just switch to different headphones to get different flavors instead. I have realized that the headphones aren't really that important, they are all almost equal overall but with different colorations. What really matters is AC power vibrations, ground vibrations, and vibrations of the component itself. In a single box setup vibration control is 99% of the sound. |
Originally Posted by tourmaline /img/forum/go_quote.gif I would say, power supply, power sections, power cable, vibration control and fuses. I just rolled fuses, one of the last things and boy, did one fuse make a difference! ![]() |
Originally Posted by tourmaline /img/forum/go_quote.gif Also good IC's make quite a difference. |
Originally Posted by tourmaline /img/forum/go_quote.gif Headphones have all to a degree some colouration, but detail/staging is what makes some better then others. |
Originally Posted by tourmaline /img/forum/go_quote.gif No wonder, 6vmrs is very loud and you can hear everything much louder, perceived detail. |
Originally Posted by tourmaline /img/forum/go_quote.gif Depends on the source, my dedicated headphone rig is miles ahead of the PC system. And i use a good souncard and good expensive drives. Good power cables make a lot of difference but i don't think it is the answer to everything. |
Originally Posted by Patrick82 /img/forum/go_quote.gif I have found that AC noise is vibrations. I got the best sound with a 7cm Valkyrja. The shorter the better! Some people like to trade detail for boomy sound. |
