zhgutov
- Dec 17, 2014
Oh, you have V280 instead of V281. It seems like these amps have slightly different implementation of pre-gain.No matter how much i turned wolume on -5 setting, it never sound as good as 0 db setting.
According to the scheme in manual, the pre-gain section in V280 is placed before the volume control, while the pre-gain section in V281 is placed after.
This might be due to the pre-amp inside V281, which has it's own gain switches, but shares the volume control.
So, it is possible that you can have different effect of the pre-gain in your amp.
In my experience with the V281 when I just switch the pre-gain it seems like I have a difference which is easy to notice.
This is because the standard volume control, which I have, has the "steps", which change the volume by the different value.
So, it is easy to think that the level is nearly the same, but actually it is not. This lead to the perceived difference in sound.
But when I try to match the volume the difference becomes less noticeable when the volume levels are closer.
This is interesting effect when the starting volume, and the sequence affect the result.
You need to start with the same loudness trying the different sequences in comparison.
Otherwise it is easy to fool yourself.
