3083joe
- Apr 25, 2014
Merry Christmas Everyone.
Been a while.
Still rocking the HD800S with V281
Happy
Been a while.
Happy
I would think twice of going with the Wells Milo if I were you(at least do some research), it seems like a "you get it or you don't" kinda amp, I've seen people praising these amp but also seen people say that they don't like it, especially for the price.
The v281, Ican Pro and the woo has excellent reputation here in headfi.
I was actually thinking of getting either the v281/v280 or the Ican pro, but from what people say Ican Pro is a good option if you like to taylor the sound a lot, while overall performance is slightly behind the v281, but if you value flexibility, you may like the iCan pro.
As for SS head amp goes, I guess V281 is pretty much end game for me and many others.
For tube amps, I really like the idea and think they are fun to play around with. However I know myself well enough that if I go that route, it will quickly become an endless quest of seeking for perfection that I would not even know what it is.
plus constantly keeping a bunch of spare tubes, warming up before listening, and remembering turning it off are also a bit of annoying to me...
If I were to get a tube amp, I'd just skip all the entry to lower middle levels, and get a WA22 as start.
Hi Guys,
I was thinking of purchasing one with sales and all, i was thinking of going stock without the options, but i thought it's best if i ask around a bit.
I saw options such as vc1, vc2 which i think means volume control, how useful is it and do i really need it?
It will be paired with Schiit Gungnir Multibit and Focal Utopia, and I listen in medium to high volume.
Other than that, this amp is has been in the market for a while, is it a good idea to wait for the successor? but I guess it will be more expensive when it comes out..
thx.
Hello folks and happy holidays.
I sort of forgot this amp existed, so I thought I'd ask for thoughts. I'm considering a few amps to pair with my Chord 2Qute DAC and Audeze LCD-4's:
iCAN Pro
Wells Milo
Woo WA6-SE
I listen to a lot of Jazz, pop, hip-hop, electronic, etc. so low end performance is as important to me as detail and clarity. My budget is around $2k.
Am I in the right place? Or are the others better options? (Hoping someone has experience with any of the above along with this V281).
Thanks!
Btw, I keep meaning to post this but always forget.
Please DO NOT use an adapter to run single-ended headphones from the balanced output of a V281. Or any Violectric headphone amplifier. Or any other brand of headphone amp, for that matter. Those adapters can DESTROY your amplifier. This is not a theoretical "maybe it's a bad idea...." type of thing. This is a DANGEROUS and very real way to kill your amp, and it's happened before on several occasions that I know of. Don't be tempted!
Balanced headphones can use an adapter to run from a 1/4" jack. That's fine. But the other way around is a big problem!
Thanks.Btw, I keep meaning to post this but always forget.
Hi Fried, what if the female was a 2.5mm TRRS. So balanced to balanced. I assume there are no inherent risks here?
Just for illustration, picture taken from Amazon
https://www.amazon.com/SX-T-3-Balanced-Headphone-Cable-Adapter/dp/B01MYS8DG8
The above adapter is the best way to cook ANY balanced headphone amp.
What happens:
A true balanced amp has 4 amp sections, left inphase, left out of phase, right in phase, right out of phase.
Using this adapter will shorten the left and right out phase amps in a way that they will act against each other.
They will get hot because of overload.
With some luck only fuses will blow.
With less luck the transformer and/or both amps will be blown.
Further damages may also ruin the remaning amps.
Please note that all this is not a design issue.
You will also have no garantee repairs when filling diesel in your car instead of gas.
Cheers, Fried
Thanks. That's what I assumed but wanted to confirm with some people much more expert than myself!I'll let Fried answer for himself, but I have been using such an adapter for years with a couple different balanced amps (including my v280) without any issues. As you message implies, the 2.5mm TRRS does not short two channels together.
All of my headphone cables are short with male 2.5mm TRRS termination for portable use with my balanced DAPs. I use the adapter (which is 6' long) to listen to my desktop system.
TRRS may be okay if you connect it by 4 cables to the headphones correctly. But TRS is not.I'll let Fried answer for himself, but I have been using such an adapter for years with a couple different balanced amps (including my v280) without any issues. As you message implies, the 2.5mm TRRS does not short two channels together.
And you should know exactly what you do, because it is easy to put TRS into TRRS socket, which will connect two pins.
Actually, I don't understand the reason to connect TRS to 4-pin XLR at all. This can not make the connection balanced.
