Klonk
- Jun 16, 2008
Hi guys,
For the Mac users, did you encounter any issues by going to OSX 10.11 El Capitan with the integrated USB Dac ?
I'm having some disconnections from time to time between the DAC and the computer (MBP with OSX 10.11). The sound goes off after a few minutes, and I have to shutdown the Vio and restart it.
Since I skipped Yosemite and went directly from Mavericks to El Capitan, I was wondering if I was an isolated case or not.
(I reinstalled the drivers)
Cheers
El Capitan now requires device drivers to be signed and removed the switch to disable that check. The drivers for the standard USB board offered with the V281 are not signed, so they won't load on El Capitan. There's a newer USB receiver in use in the V850, don't know if there's a new version of the board for the V281 available though. Sorry...
Since you own a MBP you could contact Violectric and try to exchange the USB board for either the newer USB receiver if they offer that version for the V281 or an optical input: the MBP has an optical digital out...
Excuse me if I'm wrong, but shouldn't you be able to fix this with disabling the "rootless" mode? (Whoever thought that was a good idea to introduce.)
With V281 it doesn't matter whether input is SE or balanced. In fact internally the pre-amp is single ended, only the power stage is balanced.
So you can feed it with Hugo and you won't lose anything.
Depends on your definition of true balanced. IMHO it's something that isn't worth fussing over.... Some amps are fully balanced dual mono designs, others are some variation of partially balanced, and others are totally single ended but with an XLR output for maximum compatibility. They all have potential to sound great, or not, based on a number of factors.
The reason I ask is that I have just sent my T1's off to be reterminated to a balanced connection with the expectation of an improvement when using with my v281. Hope I haven't wasted my money!
