Fegefeuer
- Mar 17, 2011
Updated and cleaned the starting page.
In SE mode V281 uses one power amp per channel. By converting your hps to balanced you are allowing it to use all four onboard power amps, i.e. 2 per channel. I have never heard T1s with the V281, but for all my headphones the difference this makes is substantial.
I wouldn't worry too much about the SE preamp: it's the power stage that makes the difference. Having fully balanced end-to-end amp might feel better, but it would complicate the design and make it more expensive, with negligible impact on sound quality.
Originally Posted by gonzfi /img/forum/go_quote.gif
A further question on this if you wouldn't mind....
If I connect my dac (nad m51) to this amp with either balanced xlr cables or standard stereo interconnects, will that make a difference to the balanced output? Thanks.
Thanks for the advice.... So I therefore deduce that if I were to use a Chord Hugo instead of the M51, the fact it doesn't have a balanced output shouldn't make a huge amount of difference? Obviously there will be a difference because it's a different dac.
