JeffMann
- Oct 27, 2014
I think question #1 has already been addressed.
As for #2, how does it sound unbalanced on the same recording?
I enjoy Classical and listen to live concerts frequently. To be honest, and without further feedback, I think you may actually have a wonderful problem which is increased dynamic range into the HD800 that V200 was unable to reach previously.
In a large concert hall a single instrument can sound a bit faint and distant. A fortissimo isn't called a fortissimo by random chance.
I'd rather not get into the burn in thing a lot. From personal perception, all new electronics need to "settle down" and it takes a few hours of play. Leave it on a couple days and see if the sound changes a bit.
Congrats on the "problem" and welcome to HeadFi
Consider this recording of Stravinsky's Rite of Spring - http://www.amazon.com/Stravinsky-Rite-Spring-Pulcinella-Suite/dp/B000003CXF/ref=sr_1_1?s=music&ie=UTF8&qid=1414448807&sr=1-1&keywords=rite+of+spring+levi
It has a very large dynamic range, which my V200 can cope with in the sense that when I set the soft passages (usually an individual instrument playing softly, but distinctly and not faintly) to suit my personal hearing as I recall the same instrument sounding during a "live" performance from a good concert auditorium seat, then the loud passages are very loud but still controlled and undistorted/smeared/congested. The loud passages also sound consistent with what I would likely hear when listening to a "live" performance (presuming a seat that is not too close to the orchestra). When I set the soft passages to the same auditory level using the V281 (rather than the V200) then the loud passages are unnaturally loud, and also slightly distorted. I was wondering whether this problem could disappear when the amp finally complets its "burn in" process. By the way, I define "burn in" as the length of the time period for sound reproduction faults (that are not inherent to a particular piece of audio equipment) to finally disappear. Examples of those "burn-in" faults may be i) a woofy/non-taut bass-end, ii) an exaggerated treble end, and iii) imperfect soundstaging. For example, my AKG710 headphones took between 200-300 hours to "burn-in" while my Sony EA5400ES CD-player took as much as 500 hours to "burn-in" in terms of frequency response faults and non-optimum imaging/sounstaging behavior.
Jeff.
