sahmen
- Apr 6, 2014
I'm assuming you used the balanced out??
Yes, balanced out. I had the cable on my T1 v1 detachable-modded and re-terminated with a 4-pin XLR connector for that.
Hey all,
I've just undertaken some MAJOR rig upgrades. I bought a Clearaudio Concept turntable, a Violectric PPA V600 phono stage, AND, a pair of Focal Utopias.
My V281 is still the centerpiece, but these updates have brought me to a whole new level of musical delight.
I just posted my review of the Focal Utopia. I can say that the synergy with the V281 is absolutely phenomenal.
http://www.head-fi.org/products/focal-utopia/reviews/17726
-Aaron
Sonarworks Reference 3. Completely transforms the HD800 for the better.
http://sonarworks.com/headphones/overview/
I've gone for Lavri Cables this time around:
http://www.lavricables.com/cables/master-silver-sennheiser-hd800-upgrade-cable/
On its way to me as we speak :¬)
So, what are your impressions once you went balanced?
Did you play around with the pre-gain? 0db vs -12db? Curious about your findings. Take your time though, there's plenty to hear now.
Thoroughly happy with this amp, best I've heard to date.
Better than the 600i though?
Speakers versus headphones - not really a fair comparison.
The cable only arrived this morning...
... however the upgrade is significant. More so than I anticipated. Extra control, air and dynamic punch. Lavri recommend 150 hours burn in for this silver (pure 12 core 6N) cable, so I look forward to further improvements.
I've also had more time to spend with the V281 + Abyss (balanced), and again, it's been stellar.
Thoroughly happy with this amp, best I've heard to date. Bear in mind transparency is key for me being a music producer/mixer.
I spy an RME ADI 2 PRO in your setup... is that your main DAC? Care to comment on it as I am considering getting one myself.
Well spotted! Auditioning it as we speak. Takes a little while to burn in, and the Slow filter is much nicer (smoother) than the default Fast filter.
It's incredibly good. DA and AD ability competes with much more expensive single units. Headphone amp is very capable too. Not sure how RME managed to do it. I won't be keeping it though as I need a monitor controller (going for the Avocett IIA as the new Quantum DAC is consistently reported as sublime).
If you're building a studio and need a single centrepiece, this thing cannot be beaten. And it's tiny!
It certainly looks very capable and reasonably priced. I may sell my Hugo TT and replace it with one of these and spend the difference on some new cans!
