leftside
If you want more bass, just turn it up on your preamp
Ain't the same thing. Plus why have a preamp with the headphone amp and 2 volume controls? Sell tube amp and preamp and put the money towards a better DAC or headphones.
I got a new V281 with the fancy motor volume knob to demo. I'm wondering if you guys have any thoughts or advice. This seems a little off/wrong too me.
1) With the V281 volume set to zero, I still hear sound. Shouldn’t zero be black/nothing/full attenuation? Is there something wrong here?
2) If I manually turn the knob to adjust sometimes I can hear a somewhat nasty pop (aside from some audible clickyness there too with manual adjustment) For such a premium volume knob is this considered normal? If I use the remote control I don’t hear the clicks in the adjustment nor the occasion pop as often but it still can occur. For something that costs an additional $580 this seems kind of janky. I'm not talking about the audio clicking when the motor moves the knob.
3) It also seemed to be pretty hot on the sound for me so I adjusted the dip switches on the back to -6. I found it funny since some of what I read said with the Audeze LCD-XC that some feel it can benefit from +6. I don’t think the Mytek Line out is unduly hot.
I'm using balanced XLR from DAC to Amp. I checked the Mytek docs on their outputs and this is what it says briefly:
XLR output DEFAULT :
Average level (0 VU) = +4dBu= 1.228 VRMS on XLR (between pin 2 and 3) Output trim (adjustable in menu) = -18dBFS
This is the typical professional recording setting well handled by professional and some hi-fi equipment typically powered by +/-15V power rails (or larger)
It's recommended for Hi-Fi systems with well designed high headroom preamps and amps.
Anyways, the V281 sounds pretty good to me, but but.... is this normal? I don't think the output from the DAC is abnormally hot. At least my other amp doesn't have this anomaly.
I'm wondering how you don't find the Mytek bright. It's the brightest DAC I ever heard. Interestingly many who have the Mytek pair it with warmer tubes. Not sure about yours though.
This doesn't sound like mine.
I have the same one (no dac)
Clicks yes as its a 128 step relay nob
I did hear a little sound with volume on zero with my dads phono stage but the gain was set to high for it.
No sound at zero with my project phono stage and no pops at all!
Also had to go to +6 gain for my hd800 S to sound best.
Well I hope you get it sorted. I have to say I also have been disappointed in the 500+ nob but what can I do now. Sold the wa22. But it's all good. Just use remote and don't notice it.
I believe the -12 will be enough tho.
Keep us posted.
Thanks.
Been a long time of V281 owner, recently finally decided to upgrade my amp from V281 to the Moon 430HA. It's a hard decision, but time to end my game...
Have you both tried the 430HA and preferred it?
PS. This game has no end
