For the low impedance hp that I use, I leave the dip switches at the null setting 0dB. For the high impedance hp that I use: Auteur ZMF, 0dB; Beyerdynamic DT880 (600 ohm), +12dB; Beyerdynamic DT1770 (250 ohm), +6dB; Sennheiser HD600 (300 ohm), 0dB.
Interesting. I set mine on V280 to be -12db so that I have more headroom on the vol pot. Sound-wise; to my ears; not much difference regardless of dip settings.
The lack of XLR input on the V340 is really unfortunate. When music signals go through my Mojo Audio EVO Mystique DAC to the V280 via XLR cables then to hp via XLR cables, the dynamic range and soundstage are outstanding.
I dont have yet the cable with plug XLR, but I have connected the qutest(DAC) by RCA to the amplifier (unbalanced connection), if I connect the Headphone with XLR cable to the violectric,
1. Will the connection work with the plug XLR?
2. Will I benefit from this type of connection?
XLR input on the back makes no difference it isn’t even true balanced.
XLR output on the front to the headphones makes a huge difference! It doubles the output and gives you one full amp per ear.
keep your qutest (great setup you have!) on rca and make sure your headphones are wired for Balnced XLR. (Unless the headphones are very sensitive, like iems, grados, B&W)
Senns and ZMF are absolutely brilliant balanced out of the v280!
Imo the balanced make a difference. Hard to say what but it is a bit like new and more powerfull batteries.
Sounds strange but there is more power. Not the power is the profit, or it is, but more the spare power.
I think.
What am I saying?
What interlink do you use between the Qutest and the V280?
In my, same, set up I noticed a very big difference between some.
Tried MIT, Siltechs, John van Gent and others. Just like in my favourite shop I finished Crystal Cable.
Just curious.
Just curious.
since he is using a qutest, it would make no difference. Qutest only has rca, and chord dacs are always going to prefer running single-ended for most transparency.
XLR in on the v280 gets converted to single-ended immediately, so it does not benefit from balanced. However, some sources my benefit from XLR out, which is probably why they put XLR in on the 280
