- Jan 29, 2010
Has anyone had any issues installing the driver (XMOS) on a windows 7 machine? The driver installs but the V850 just isn't recognized.
Any advise is welcome
Is it getting sufficient power? Are you using a usb hub splitting bandwidth/power distribution? Try without the hub if so. Maybe try a different usb port (usb 2/3) isssue/conflict. I get some issues using a usb power isolator if my usb microphone is plugged into the same usb lane of my motherboard; simply not enough power/bandwidth for both. Moving one to a different lane resolved the issue.
note: this is with a different dac, but can be universal solutions.
Some usb 2.0 dacs absolutely don't work on usb 3.0 ports in my experience as well. Not sure what else to suggest trying at this moment. Hope one of those suggestions works for you.
Thanks for the quick reply, I tried on the usb 2.0 and it worked. thanks!
We need reviews and impressions! I can't buy this purely on how cool it looks on top of the V281 amp!! Or can I.....
I had both in my system but I didn't compare both the V800 and V850 at the same time. The V800 was in my system for a few days prior to my V850 arriving and they crossed each other in shipment back to Violectric-USA. I was in the market for a new DAC so I originally purchased the V800 (with the lower price and the current 15% discount it was truly a great value for the money). I too also had some issues with USB drivers on my Mac and because of that reason decided to go with the V850. In terms of sound... the V850 has a similar sound signature to the V800. If you like the V800 I think you will like the V850 even more. Basically larger sound stage, wider and deeper, more transparent, slightly better dynamics and much better defined low bass with the V850. It is not a night and day difference...especially in my Headphone Rig. When I auditioned the two on my speaker rig the differences in sound stage size layering and imaging is more pronounced between the two with the V850 performing much better. The V850 is more of the V800 in my opinion. The Violectric house sound remains the same between the two units.
