Violectric DAC V850 - General Discussion and Impressions Thread
Apr 1, 2024 at 4:19 PM Post #571 of 588
Indeed 😵 unbeatable price! ($1699)
I strictly need a slimmer/narrower (25cm max width) DAC, though, to go into my Hifi setup.
Then it is the Bifrost 2/64 or the Soekris 2541 which is exatly 25cm wide.
Edit: But if you find the space, trust me (bro), get the Yggi GS2.
Apr 1, 2024 at 4:30 PM Post #572 of 588
Apr 3, 2024 at 2:04 PM Post #574 of 588
Does anyone of the V850 owners have any experience with the Soekris 1541/2541 or Metrum Onyx/Jade or similar R2R DACs paired with the V281? Does an R2R DAC significantly improve the performance of the V281?
More generally, did anyone here compare the V850 and a Soekris F2F on any Violectric (222, 281, 550, 590,…)?
Apr 3, 2024 at 4:26 PM Post #575 of 588
I am sure there's somewhere on this forum. The question of whether or not an upgrade from a v800 to a v850 is of much difference? I would assume that it's probably very small percentile. Have many of you decided to go with the Amp/ Dac combo instead of an V850?
Apr 4, 2024 at 8:48 AM Post #576 of 588
According to Fried, the different is quite substantial between the V800 and 850 apparently.
Apr 4, 2024 at 8:51 AM Post #577 of 588
Damn. I wish there was more communication with these guys on YouTube. They don't get enough screen time for the quality of the amp. Maybe that's a good thing cuz it's already super expensive in my books for me. However, other than the one reviewer can't think of his name right now, draw me a blank. No one else reviews the gear. Mind you some of it's like 10 years old. Okay, everyone wants the fancy new topping amps. That'll all be in landfills in 10 years. I think I'm going to have to start up a YouTube channel and review some of these old amps/dacs that are made like bricks.
I would like to know what is the big difference but they're not even making these anymore. So I guess only the people that find the hidden gems will actually be able to find out with their own ears. The rest will just have to take his word at.
Apr 4, 2024 at 8:57 AM Post #578 of 588
for me, i think his word is pretty good.. enough for me to scramble for a V850.....
then again, if you have a V800 thats still a damn nice DAC. better than a lot of other DACs that cost a lot more than it.
Apr 8, 2024 at 8:58 AM Post #579 of 588
I have a Soekris dac2541 as a loaner, here are my toughts:
These are tonally identical, organic and realistic sound (organic= lifelike, natural)
- Soekris does seems to have more detailed sound.
- Vio has a larger image
- Soekris has more impact, but vio hits with a larger volume
- Separation is not as simple to describe, Vio image is larger, and sound placement it easier, however Soekris has a cleaner sound
and as such instruments are cleaner in that narrow space
- Vio sounds vintage in comparison, but not in a bad way. The analogue approach is better suited for some.
- Midrange is identical
I will say that Soekris is the winner here, tough I'm not changing my DAC to it. V850 stacks nicely with my V222 :D
Just a remark: If there is time between dac changes, I would have a hard time to separate these two.
EDIT: After some more listening:
- Midrange still identical
- The detail goes like this: With Soe I notice a detail that I have not heard or focused on before, but then when I listen with Vio, it is there also, just did not hear it before.
- Vio sounds clearly smoother, and the vocals are slightly closer to you also.
- Bass is almost identical, cant even describe what is different with these two
I am listening Tool - Chocolade Chip Trip FLAC
Doing this comparison made me realize how hard DAC comparisons are...or my Stealths / Elites are just not detailed enough :D
Apr 8, 2024 at 12:06 PM Post #580 of 588
Thanks so much for this @FinHifi ! That’s exactly the comparison I was after!
Would be great to hear the same for a comparison with the Holo Audio Cyan2 🤓
Apr 9, 2024 at 12:22 AM Post #581 of 588
Thanks, both are excellent in my opinion. I actually listened Vio thinking it was Soekris, and was convinced that I need to upgrade my DAC.
Difference between these two is small, but Vio is definetly the smoother sounding one.
Apr 27, 2024 at 8:00 AM Post #582 of 588
Looking for a V850 anyone wants to sell or trade, let me know.
Apr 27, 2024 at 8:34 AM Post #583 of 588
I have the Yggy+ GS2 and I have used the Soekris 2541. I didn't have them side by side, both pair well with the v281LE and v222. I'm passively interested in trying the Vio DACs. Just for the sake of matching and design.
The only downside of the Yggy is the size....
Apr 28, 2024 at 12:57 AM Post #584 of 588
What do you think about V281LE? How good it is?
Apr 28, 2024 at 5:39 AM Post #585 of 588
the Violectric DACs are excellent, i had an V800, and stepped up to the V850.... According to Fried, theres a considerable difference... then again the V800 is still a damn nice DAC. great performance from a compact unit.
