So an Iggy it is.
Thank you!
Thank you!
Keep in mind that I haven't actually heard the Yggy or the Gumby before bying. I'm very happy with the Yggy, but still haven't heard the Gumby. I know some people that may prefer it. My decision is based on my experience with other DACs (the full range of Chord DACs, Benchmark DAC3, Metrum Onyx, Violectric v800 and the less expensive Schiit multibit DACs) and a lot of praise on the forums for the Gumby and Yggy.So an Iggy it is.
Thank you!
Imo, V280+DAC or Element X or Monoprice thx 887+chord qutest. All 3 should be really really good.V850 vs Benchmark DAC3-B vs Chord Qutest? Chord has no balanced output though.
Amps I'm considering are V280, THX AAA 789, or... maybe I just get an all-in-one like Matrix Element X. Or go even more simple with the V280 and optional built-in DAC.
2) With the RS05, the recommendation I read is to switch off the resampling function on the V850 but to use the re-sampling and Femto clock on the RS05 instead, but wouldn't it be a wasted functionality on the V850 ? If I choose to switch on the re-sample on V850, does it mean that I am wasting my money in getting the RS05 ?
If only there is one product that combines the V850 and RS05... (is this the proposition of the new and upcoming Niimbus dac ??)
Yes
And I think it is better to use AES/EBU (XLR) to connect them digitally.
Thanks for the tip. My current chain is Macbook Pro > Audirvana > Totaldac Filter > Wyred4Sound Recovery > Herus(replacing with V850) > V280 > HD650/Mad Dogs.
How can I use the AES/EBU on the mac which is restricted to USB line-out ? what would you recommend me to add/buy to leverage on the superior AES/EBU connection from mac to RS05 ? No problem with AES/EBU from RS05 to V850.
Note: I have already purchased Violectric balanced interconnect(V850 > V280).
I see. Then I can skip the purchase of USB interface and just go for the Femto option. Thanks for the great advice ! Didn’t know Violectric has AES/EBU cable too. Will ask Arthur. Cheers.I use MacBook Pro as the source too (one of the sources), I use its cheap optical out.
It does not matter which interface you use at the input of RS 05.
But you need to use a good interface between RS 05 and V850.
This is important, because you want the best possible signal at the input of the V850!
No need to spend lots of money for XLR, you can use short Mogami Digital Gold XLR cables, for example.
Violectric can produce AES/EBU too, as I know.
