FumblingFoo
Well, I just made some pictures to get an idea of the resampling quality inside DAT RS 05.
This "measurements" are made with the USB loopback (TENOR 8802 PCB).
Analysis is performed for the signal downsampled from 96 to 44.1 kHz.
Here you can see small previews, click to open larger versions.
THD+N (L @ 0 dB FS, R @ -60 dB FS, noise floor is limited by FFT size):
FFT for sweep tone:
Impulse response:
Test signals are taken from http://src.infinitewave.ca/
The same resampling module (SRC4392) is inside RS 06, V800 and V850.
WOW! That THD+N graph is INCREDIBLE! That's like MSB Tech territory ($$$,$$$.$$)! Nice job @ you and fried!
Would these performance levels pass through the V800 / 850 (with resampling off) for amplification as well, instead of being reduced to V800 / V850 levels (@ ~-140db, which is still really good)? Would / does jitter measure similarly? Sorry for all the questions I'm just a little overexcited lol .
