enthusiast
- May 31, 2004
Can somebody comment on SQ of the V850 in comparison to the V800? Anybody tested this mothership yet? I could score one for $1100K, but I cannot compare.
It has !!
In case you use Windows Operating System (I would recommend MAC or Linux for all things Audio), you need to go into Energy Options and switch your current profile to "High Performance". This is explained here: https://www.native-instruments.com/en/support/knowledge-base/show/3671/windows-78-tuning-tips-for-audio-processing/
@ hypersonic
The USB Regen is a device (like many others) which isolates the USB datastream from the computer.
This may be made "asychronous" or "adaptive" - most times those manufacurers don´t go very deep in their explanations.
You can remove your Nvidia Driver and use a windows-based driver. As a power-supply I would recommend a BeQuiet Dark Power Pro, it is not audible and is the highest quality power supply I ever owned, and I owned many good ones. Good luck!
Or for (much) more performance you could always go Linux, it's free and the community provides tons of excellent audioplayers, like Banshee (shown below). You can even install yourself a real-time kernel in order to get even higher audio performance.
Sorry if this is going too offtopic, but Linux absolutely positively will solve all your problems and only introduce new ones in the domain of Peripherals like Printer and Scanner, but that's it! You will sacrifice nothing except these two devices if you have them already, you will be gaining a lot. To go back on topic: A Windows Laptop is probably the most horrible choice you can do for Audio Quality. The internal PSU is -to be frank- horse**** compared to a $100-$200 PSU Unit from Seasonic or BeQuiet. With quiet I mean also the noise you are hearing in your headphone, this is maybe the afformentioned "Jitter", but I just call it PSU noise. In any case, except you own a Alienware Notebook, I would suggest to go Desktop as Audio Source.
Sticking to the topic, I found that using android phone (it's linux based I know that) works with the V850 via OTG.
From Android 6.0 it seems to be supporting external DAC as there is "audio source" in USB configuration so no special playback software is needed. I tested on android 4.4.4 with USB Audio Player PRO though.
Perhaps an android tablet could be the cure?
You dont need to type anymore in Linux. Those days are long gone. You see Android is not Linux-Based, it is Linux, and this is why you dont have any problems with it when it comes to audio. Windows Audio-Architecture is just crap afaik. Mac or a Linux real-time kernel is far superiour. Also FLAC, ALAC, OGG, everything just works out of the box in Ubuntu. Maybe you could try a Dual-Boot on your Laptop for trying it out? Or use 2 harddisks, something I did before switching all our household and office computers to Linux 5 years ago. When you are fed up, you just switch harddisks. Check this page out: omgubuntu.co.uk Good luck! /offtopic
In the meanwhile I have ordered myself a Violectric v800v2 for less than half the price of a v850. And will be reporting on how it sounds. I am planning on connecting it via 75 Ohm COAX Vector Cable by SommerCable to my ASUS STX as source. Any better ideas on connecting? Maybe a dedicated RME PCI card? I am planning on connecting both violectric devices (DAC + Amp) by an Albedo XLR Cable also by SommerCable, its the most expensive I could find before Vodoo level, so it better be good.
Looking forward to buy V850
Waitingf for big review
