Violectric DAC V850 - General Discussion and Impressions Thread
Nov 29, 2015 at 3:28 AM Post #166 of 588
  Ok I have been following this thread and the discussion about the XMOS not supporting 176.4
Well I am able to play 176.4 files on my V850 using Amarra and my MAC's so am I missing something here or is the no support strictly a Windows based problem with the XMOS?
My Amarra software shows the the it is playing gall my 176.4 files at 176.4.
I asked the same Windows question a few days ago.
Nov 29, 2015 at 1:13 PM Post #169 of 588
Actually my Wadia 321 Sabre based DAC & XMOS USB also plays 176.4 with my MACs without an issue via Amara.
So for me neither the Burr Brown Based V850 or the Sabre based Wadia have anny issues with 176.4 files on my MAC via Amara.
Both DACs are XMOS USB.
Nov 29, 2015 at 5:55 PM Post #170 of 588
Maybe Mr. Reim will chime in and explain about V850 XMOS. Violectric may have really good reasons to choose this particular chipset and implementation. That said, if you are able to play 176.4 kHz through the USB input of the V850, it could probably be sth Windows-related.
Nov 30, 2015 at 6:03 AM Post #171 of 588
wow, how many 176.4kHz sample rate songs do you guys own?  And surely those tracks have alternate sample rates you can download...
Very few in reality, so it's not really a show stopper for such an appealing product.
Still, one might want to do 4x upsampling for redbook material, so that sampling rate support might be useful.
In the specific case of the v850, which natively support customizable upsampling, this is definitely a minor issue.
From what I read in the latest post it might even be driver-related, am I right?
Dec 1, 2015 at 9:58 AM Post #172 of 588
I´m chiming in ...
First of all I am glad that there are some folks carefully reading the manual AND our web site.
So all our efforts are not in vain
Iindeed there are some things to adjust together with the 192 kHz X-Mos USB interface.
And the answer concerning the sample rate / resolution with the X-Mos USB chip-set differs again for Windows and Mac.
Mac users can be glad because the X-Mos chip-set supports:
- all sample rates: 44.1, 48, 88.2, 96, 176.4, 196 kHz
- both resolutions 16 and 24 bit
... and all this for all current OS without the need of proprietary drivers
Windows users must have installed at least Windows 7 for the X-Mos chip-set - but all newer OS, namely 8, 8.1 and 10 are stable working.
They also have to download the driver from our web site which supports:
- 44.1, 48, 88.2, 96, 176.4, 196 kHz sample rate with 16 bit resolution !!!
- 44.1, 48, 96 and 192 kHz sample rate with 24 bit resolution - NO 88.2, NO 176.4 with 24 bit resolution !!!
So the rather rare double or quad speed files have to be converted to another sample rate before.
Red-book compatible material (44.1 kHz) is better converted inside V850 to a higher sample rate that inside the computer.
The sample-rate converter integrated in V850 will surely do a better job !
So I would rather suggest that the Tenor 8802 chip-set would be the better solution for the Windows world as it supports
the complete set like the X-Mos solution does for Macs ...
Thank you,
Fried Reim
