bigshot
Yes this is true, but has been proven to not be the case in this sceanario. Thus, it is either psycho-acoustics at play, or some inherent advantage in DSD. That's the rub.
Did you match the line level?
You keep saying this and that is better than those and these, but you haven't given anyone any information as to how or why DSD is better
Yes, of course.
Pics or it didn't happen for a line level?
Do you want an audiologist report too?
Just decided to abandon CDs. I am not even close to understand all the technical discussions u guys have here. I used my ears. Maybe it is just me, maybe not just me. Vinyl rips gave me wow factor that sacd cannot.
It is like magic, this fluent flow of passionate and natural music finally freed me from searching for better formats along the path of flac, aiff, dsd...It also freed my headphones T1 then we can concentrate on what really matters - music.
Close my eyes, music starts, nothing else matters
I record in DSD. At first I was using Korg MR1 , capable of recording in DSD64 or DSD at 2.8yxz MHz. Now I record with MR1000 in DSD128 or DSD at 5.6xyz MHz.
1GB = 22 minutes DSD64 audio
1GB = 11 minutes DSD128 audio
A typical recording session amounts to about 15 GB. If there is a large(r) project and I record both recording meant for speakers as well as binaural,
meaning I am running two DSD recorders in DSD128, after all is said and done, total can exceed 50 GB - per day...
In the afternoon I am visiting my computer guru to set up a RAID5 enclosure with 5 pieces of 2TB hard disk drives, which will give me 8TB of capacity with the very minimum redundancy and safety I am still *somehow* comfortable with. I do not want to mess something up, I want to transfer my backups to this RAID5 setup bit perfect - just under 2TB of my own master recordings I certainly do not want to go to waste. This will take a while...
So - here you have the answer. If you plan to go DSD route (or any other hirez) - HDD manufacturers are looking forward to you. And please reserve your comments SSD are better than HDD . Yes, they are - just simply not cost effective with this amount of data at the present time.
I've added a PS Audio NuWave phono and have started messing around record drops at DSD64, there is some issue (firmware) doing DSD128. Have you been converting down to any PCM, or just keeping everything DSD, and un-edited.
I'm thinking about keeping DSD128 for myself, but also more portable 24/96 or 24/192 copy. Thanks for any input!
... here a DSD64 LP rip, let me know how you liked it...
