]eep
Cleaning sleeves is delicate work. Most are printed cardboard so you can't use wet cleaning. But a moist cloth is always safe. Pencil eraser is also safe.
For stickers you can use sticker remover but this can be too aggressive on printing on paper sleeves. You can also use wax (clear shoe polish). But for stickers the most important thing to use is: patience! Give the glue time to come off.
When sleeves have a plastic coating or even laminated magic eraser is great. But i have damaged some sleeves with it. Don't rub to long or hard or wet. A little detergent helps removing greasy substances like fingerprints and chocolate. Detergent and/or alcohol. I usually fill a bottle with clean water, demineralised or distilled water and add a few drops of dish washing fluid with a few ml of cleaning alcohol (spiritus, glassex w/e name). This is my formula for cleaning vinyl on the Okki Nokki but it's also great for covers.
I use textile glue for repairing split seams. It's more flexible than woodglue (pva) and adheres just as well. Never ever use tape like cellotape or duct tape. Don't. Not ever! Or you will be banished into the deepest recesses of hell. This ruines sleeves over time. And impossible to remove once the glue has dried out.
When the open side of the outer sleeve is worn, torn or frizzy I glue a strip of 120g paper behind it if needed and cut off a tiny strip of the entire sleeve with an office paper stack cutter (big knife with hinge type). This way I have a neat edge again that helps positioning the inner sleeve back with much less wear.
And when you clean the record, fix up the sleeve, please give the vinyl a new inner sleeve. You can put the old one with lyrics beside it.
