Listening to Robert Palmer and The Church - Starfish on SPKs rig.
I have heard various opinions on mic-ing however, I can’t speak on that matter as I’m rather clueless regarding this topic. From what I’ve heard, drums and piano is the most difficult to get right. These instruments plus hi-hat and vocal rendering is usually where my focus is when evaluating recordings. Air, soundstage or imagining is not far behind but less critical. At least to me.Live takes with just a pair of studio mic’s have the potential to get closer to the original than somehow “assembling” the same thing by mixing multiple close mic’s or worse mixing tracks that were recorded at different times and places and then trying to recreate the “sound” over some studio monitors, some guys can do a really good job of it but there’s not many of those around, simple test, record 2 singers in close harmony, then record them separately and try and mix them to sound the same ? …
Instruments like bass drum and string bass can create a similar sympathetic harmony which can be lost with close mic’s and post mixing vs a live take with a couple of good studio mic’s, and preserving everything as close as possible to the original is possibly why some good recordings sound better as replay equipment improves as those subtle harmonics and inflections are more faithfully reproduced, there are some wonderful digital recordings that sound transparent, dynamic and “real” with some good post processing but they still don’t capture that truely live sound of a good band of musicians playing “tight” … bass, drums, horns hitting the same notes at exactly the right time …
In the listening room too …. Striking a balance somewhere in the middle …Just wondering... Isn't that actually what happens with headphone listening?
I know you mean: when recording. But there's a huge science behind that. Also; what is your purpose? A tiny dampened studio is a must for the intelligibility of spoken word, like audiobooks. Medium size for multitrack recording. A concerthall also has critical damping for the best music experience in most spots. Cathedrals are awesome for acapella music or mass. But the long reverb time is not good for transferring information. It's also the reason that 'reverends' or 'priests' have - - that weird way--- of speaking with---meaningful intervals--- because otherwise... Yowoouldtn'beablteuonderanadworthdewyerseayinggggg. All words smear into eachother. I'm not familiar with the correct technical term in English but it's something like reverb radius. That's is the radius where the amount of reflected sound becomes the same level as the direct sound which makes sounds hard to discriminate.
As far as popping balloons. I remember there is a plugin for foobar (and others) where you can input the sound of a popping balloon (sharp impulse) in certain acoustic environment where you can mimic that exact same environment with headphones. That worked eerily well.
Is that a first with the Bowie box sets ?I did spurge on David Bowie’s Brilliant Adventure box set. But it’s one of those box sets that I sure will enjoy for years to come.
That’s the latest that just came out.Is that a first with the Bowie box sets ?
Doing fine here with a 50 pack of external sleeves to replace the ageing ones, and a glue stick to fix the seams on a few album sleeves, keeping me busy all afternoon for less tha 20 bucks …
