DoctorZoidberg
- Dec 9, 2010
Looks great
Thanks. I'll try that the next time.. It was a bit challenging to click these as the wide apertures blurred the definition of the burls but gave an overall good picture. So I had to use a narrower aperture to retain the definition of the burls..
You need a lot of light presented as a diffuse gradient. So for me I shoot 800 joules through a strip box onto a diffuser. I shoot handheld at about ISO 200 and f18.
Yeah! Smaller object gives shallower DOF... Focusing distance is the cause iirc. I run a 100mm f2.8 macro lens. Works great!
I have noticed that any light will work if it's a diffuse gradient. It makes the reflections really sexy. Pin light is really harsh. I think Zach uses hot lights and a shower curtain! Works awesome.
I haven't been with Zach to any meets! I'm planning on hitting the next NYC meet and then we'll just have to see from there.
And yeah, the cheaper 100mm f2.8 is a great lens for in-ears!
