VGP Award Winners! 18 FiiO Products Were Granted the VGP 2022 SUMMER Award!
Jun 1, 2022 at 3:25 AM Thread Starter Post #1 of 7
FiiO
Sponsor: FiiO
Guangzhou,China
Recently, the well-known Japanese media, ONGEN PUBLISHING CO., LTD., released the winner list of the VGP 2022 SUMMER. As usual, FiiO's products got good grades. In particular, the BTR5 2021, M11 Plus ESS, and M17 were granted the Gold Award!
1. 150 thousand-300 thousand yen portable audio player gold award: M17
The M17 has the output power and sound quality that can rival and perhaps even surpass highly-regarded desktop systems. Featuring desktop-league dual ES9038PRO DAC chips, desktop-class THX 788+ headphone amp, desktop-grade power supply and gain, and desktop-level connectivity, the M17 is a perfect choice for heavily-addicted audiophiles.
2. 100 thousand-150 thousand yen portable audio player gold award: M11 Plus ESS
Employed in the M11 Plus ESS is the ES9281AC PRO chip from ESS, which
comes with carefully engineered specifications and tuned sounds for greatly improved sound performance. The M11 Plus ESS supports unfolding of MQA tracks, and MQA Renderer in USB DAC mode for complete and rich sounds.
3. Portable Bluetooth DAC/Amp gold award: BTR5 2021
The BTR5 2021 takes in two brand-new ES9219C DAC chips. Better performance and more robust decoding capacity ensure low power consumption and high SNR. It can unfold MQA tracks for master-level quality. Moreover, the one-click "dongle" mode is very convenient for daily use.
4. 120 thousand-200 thousand yen desktop DAC/Amp award: K9 Pro ESS
The K9 Pro ESS includes two high performance ES9038PRO DACs. Alongside the numerous low-noise, Ti current LDO regulators ensure excellent dynamics and low distortion with stable power supply. The upgraded PVD golden volume knob blends with the body. A flagship thus came.
5. Below 50 thousand yen desktop DAC/Amp award: K5 Pro ESS
The K5 Pro ESS employs the flagship portable ESS DAC, the ES9038Q2M with more outstanding performance and richer audio details. It supports coaxial/optical/RCA line in and 6.35mm/RCA line out for up to 768k/ native DSD512 decoding. The 3 gain levels take good care of both rich details and large dynamics.
6. Below 50 thousand yen desktop DAC/Amp award: K3
The K3 uses the ES9038Q2M DAC. The circuit design implementing this DAC has been optimized for a low noise floor and clean sound. It equips with 3.5mm single-ended and 2.5mm balanced outputs, low and high gain levels, and is compatible with driverless and high-performance modes.
7. Below 50 thousand yen desktop DAC/Amp award: E10K-TC
The E10K-TC comes with the flagship XMOS XUF208 for better USB decoding. PCM is now supported up to 32bit/384kHz sampling rates. It has high/low gain adjustment as well as bass boost. The USB Type-C connector gives the device more compatibility. At the same time, the headphone/line/coaxial outputs make it easier to connect to other equipment.
8. 10 thousand-30 thousand yen small DAC/Amp award: KA3
The compact body includes a high-performance ES9038Q2M. The robust decoding supports up to 32bit/768kHz and DSD512. Dual headphone outputs, 3.5mm single-ended and 4.4mm balanced, satisfy multiple use cases.
9. Bluetooth transceiver award: BTA30 Pro
The BTA30 Pro employs the high performance ES9038Q2M DAC, making for wider dynamic ranges compared to portable devices. LDAC transmitting and receiving are both supported with sampling rates up to 384k/32bit and native DSD256, which can easily deal with multiple use cases.
10. True Wireless Bluetooth amplifier award: UTWS5
The UTWS5 utilizes an independent low power consumption AK4332 DAC and flagship-grade QCC5141 Bluetooth chip, supporting Qualcomm's third-gen TWS Mirroring, Bluetooth 5.2 and aptX/aptX adaptive/LHDC wireless Bluetooth. Thanks to the Snapdragon sound suite of technologies, we can truly experience wireless 96kHz/24bit high-resolution audio.
11. 50 thousand-75 thousand yen in-ear monitors award: FD7
The pure beryllium diaphragm dynamic driver IEMs FD7 is built in with an ultra-large 12mm pure beryllium dynamic driver that features exceptionally swift transient response and remarkably rich sound. The FD7 comes standard with three pairs of interchangeable sound tubes, each with a different inner diameter for different sounds. The high-purity monocrystalline pure silver cable and 3 audio plugs of 2.5/3.5/4.4mm allow more options for more ways to listen.
12. 50 thousand-75 thousand yen in-ear monitors award: FH7
The FH7 features Knowles custom quad balanced armature setup+13.6mm beryllium-plated driver and high-purity monocrystalline silver-plated copper cable LC-3.5C. The high-end driver combo working with exquisite sound tuning handles any kind of source easily.
13. 50 thousand-75 thousand yen in-ear monitors award: FA7S
The all-new FA7S employs a custom 6 Knowles BA setup, with each set of drivers handling a specific frequency range having their own sound chambers so as to greatly minimize frequency interference. The high-quality monocrystalline silver-plated copper cable, angled MMCX connectors, twist-lock swappable audio plugs, and Hi-Res audio certification are all here for better assured quality.
14. 30 thousand-50 thousand yen in-ear monitors award: FH5s
The old winner of VGP 2021 SUMMER, FH5s, couples with a newly developed double dynamic driver and double balanced armature acoustic architecture. The dual dynamic driver setup connects the low, bass and mids together more smoothly and coherently. There are also three tuning switches for 8 exciting ways to listen. Coming standard with swappable 2.5/3.5/4.4mm plugs, the FH5s can fit perfectly with more audio sources.
15. 30 thousand-50 thousand yen in-ear monitors award: FD5
With a timeless industrial design, the FD5 utilizes a flagship-grade beryllium-coated DLC diaphragm, providing robust power for bass. The practical designs, such as the interchangeable sound tube at the front cavity, and swappable 2.5/3.5/4.4mm audio plugs, make it comfortable to wear while bringing more fun.
16. 2.5 thousand-5 thousand yen in-ear monitors award: JD3
The JD3's driver employs a neodymium magnet with high magnetic flux for ample energy reserves. Stainless steel is the material of choice for the earphone housing. There is a built-in HD microphone with line controls that supports these functions: answer/hang up; play/pause, and volume +/-.
17. Earphone cable award: LC-RD
The brand new swappable plug earphone cable LC-RD is made of high-purity monocrystalline pure silver. With 4 large strands, there are a total of 224 wires in the cable. More wires result in better conductivity.
18. Earphone cable award: LC-RE Pro
The LC-RE Pro is made of high-purity gold, silver and copper, including 20 gold-plated + 20 pure silver + 20 monocrystalline copper. 4 strands in a total of 240 wires transmit every last audio detail. The twist-lock interchangeable audio plug design allows for switches between 3.5mm single-ended, 2.5mm balanced and 4.4mm balanced plugs.
We are so delighted for these honors, but more excited that more and more audiophiles are noticing FiiO. We will always remember it, and keep seeking improvement in stability!
Best regards,
Guangzhou FiiO Electronics Technology Co., Ltd.
Jun 2, 2022 at 2:59 AM Post #4 of 7
Love the M11 Plus, FH3,FH9,FD3 and FD7 looking forward to purchasing BTR7 when it is released. I have been purchasing FiiO products since the first generation X5 DAP and their products have continued to evolve and improve over the years, keep up the great work FiiO :thumbsup:20150624_195523.jpg
Jun 3, 2022 at 1:26 PM Post #6 of 7
Well deserved! The best performance to value audio products on the market IMHO.
Jun 4, 2022 at 1:10 PM Post #7 of 7
Best regards,
Congratulations Fiio for the award and for having great products.
Audio46 Audio46 is the destination store in NYC to demo and buy headphone products. Stay updated on Audio46 at their sponsor profile on Head-Fi.
https://www.facebook.com/Audio46 https://twitter.com/Audio46NYC https://www.instagram.com/audio46/ https://audio46.com/ info@audio46.com
