ohcrapgorillas
Does anyone know if the Garage1217 12AU7 to 6SN7 adapter can be used directly in the Vali 2, or do I need an in-between 6DJ8 to 12AU7 adapter? The description on the website says that 6DJ8 will work, but when I emailed the guy in charge he sent this in response
"It depends on what voltage the amplifier you are using is running. If it is actually 12v then it is a no go. If it is 6.3V using the center tap for 12au7, then it can work for 6dj8 too. "
Does anyone know what voltage the Vali 2 runs here? I'm asking because it appears my 6DJ8 to 12AU7 adapter got sent to my old address and I doubt I'll ever see it. I already have the G1217 adapter for use with my Crack, but if it could pull double-duty with the Vali 2 that would be excellent. And I am IMPATIENT to move on from the stock tube! I have a handful of 12AU7 and 6SN7 sitting around just waiting to be useful again....
