hollandstein
Agreed. I have some 6XX on the way and I’m excited to pair them.I think the Gold Lion seems cleaner too. The EH 6CG7 seemed muddy to me at times. More of a soundstage on the Gold Lion too.
Found some Mullard's that are for sale locally. 2 of HY90/35W4 and 1 of HF93/12BA6. Will any of these work in the Vali 2?
Still leaning all this. Thanks again for the help.No. The HY90 is a rectifier tube, and the HF93 is a pentode with a 12.6 heater voltage. Even with adapters, the HY90 will likely fry your amp within seconds, and the HF93 won't get enough heater voltage to get the cathodes to temperature (the Vali 2 provides 6.3 volts of heater voltage). There are dual voltage tubes (like 12AU7's, 12AT7's, 12AX7's, and others) out there that will operate at either 6.3v or 12.6v depending on how the heater circuit is wired for them, but the HF93 is not a dual voltage design.
https://www.radiomuseum.org/tubes/tube_hy90.html
https://tubedata.tubes.se/sheets/062/h/HF93.pdf
Patience. I'd think they'd wait at least 30 days, stuff turns up, and if they send new stuff out it's not like if the package turns up they can expect the extra to come home. Lets be kind to our vendors.Man, I will not ever be ordering from tube depot again. Refuses to admit that 6SN7 adapter is lost 3 weeks after shipping. Refused to replace, had to file a dispute. Aren't many options out there for this adapter - didn't want a chinese one, so went with one from Garage1217 instead - looks like the quality is better. So, I still have no idea how 6SN7's sound. Ugh.
Got my 6SN7 adapter from garage1217, and PP refunded my purchase from tubedepot - pretty pathetic I had to go that route, IMO. The adapter from garage1217 has really nice, thick, high quality pins that are long and gold plated. They're mounted to a circuit board, and that has a ceramic socket on top. Really nice quality. I rolled in the two types of 6SN7's I have in my stash - both NOS from what I can tell. They sound *GOOD*. Have not spent enough time with these tubes yet, but my first impression is that the bass is crisper, and that cymbal hits are just extraordinarily textured. The first LP I listened to through the 6SN7 was 'Up at Minton's' vol 2 by Stanley Turrentine - my favorite live jazz recording period. I was literally startled by the applause at the end of the first track as it appeared to float all around me. No - *literally* startled (I don't use the term 'literally' unless it is actually true). Like my heart jumped because I knew no one else was in the room with me. Have to spend some more time with this tube.
I got both, but only have about 2 weeks on the EH 6922. A quick commentary would be that the 6CG7 sounds loose and muddy in the bass, midrange is forward and bloomy at least compared to the 6922, and slightly dark treble. 6922 overall has better extension at both ends but is slightly brighter. Midrange is still bloomy but not as forward as the 6CG7.I'll post this here as it might be more relevant:
Have an EH 6CG7 and an EH 6922 on the way!
I don't plan to get any other tubes but am letting that stock tube burn in currently.
Will continue using the stock tube for at least another week but does anyone have experience with both the EH 6CG7 and the EH 6922?
What was the first tube you used in your new adapter?Got my 6SN7 adapter from garage1217, and PP refunded my purchase from tubedepot - pretty pathetic I had to go that route, IMO. The adapter from garage1217 has really nice, thick, high quality pins that are long and gold plated. They're mounted to a circuit board, and that has a ceramic socket on top. Really nice quality. I rolled in the two types of 6SN7's I have in my stash - both NOS from what I can tell. They sound *GOOD*. Have not spent enough time with these tubes yet, but my first impression is that the bass is crisper, and that cymbal hits are just extraordinarily textured. The first LP I listened to through the 6SN7 was 'Up at Minton's' vol 2 by Stanley Turrentine - my favorite live jazz recording period. I was literally startled by the applause at the end of the first track as it appeared to float all around me. No - *literally* startled (I don't use the term 'literally' unless it is actually true). Like my heart jumped because I knew no one else was in the room with me. Have to spend some more time with this tube.
