Paladin79
Previously MOT: Cables For Less
My Melz is coming around finally after ~100 hours of break-in and re-soldering the pins (both tubes had random noise issues until I re-soldered). No wild good/bad/good/bad break-in ride like the Foton, but seemed to need around the same amount of break-in time to really show off. Sounded very good to start with, but the very good wasn't quite in holy grail territory for me -- lacked impact and power in the mid and upper bass and macrodynamics were restrained. Both of those areas have improve substantially over the past 60-70 hours. Little by little it's getting pretty close to unseating Frankie.
Bill there is no way we should agree on something, if you start to like the Melz I am going to have to tell you about this other tube I got, it is so good, I can only listen to it in small stretches. My other tubes are ashamed to be in the same room.
You should hear the single triode versions of the Frankies. I just got the Sylvania xxl 7a4's, military VT-192's and they are impressive new out of the box so they should be something when they settle in. The Melz to me are not lacking in any area, so they are a standard by which I compare other tubes but that is just my opinion. The tricky part of the Vali is the tube I use in the Aune to feed it, if I really work at it, the Vali starts to sound pretty good for what it is. Getting proper bass is not easy, bass that sounds good in the Vali flat overwhelms other amps I am trying. Change part of the chain, change the sound.
