I have over 170 hours on the DC-30 so I think that most if not all of the changes from break-in are done. First off; the case on the unit is IMO much better than the original one on the DAC. It also runs very cool to the touch with no sense of vibration at all. Most here on this forum do not know me but I am a friend of Bill Allen whom most of you know from this forum. I do not listen to headphones so my observations must be taken it that context.
I have built or modified most of my gear so I have a good sense of what modifications can do. Power supplies are critical to all equipment IME. I have upgraded Audio Note kit gear (M3 preamp and Signature DAC), my 300b amps (DIY HiFi) and my current 26 tube based preamp. Without exception the power supply improvements are easy to hear. The Teradak is no different.
The improvements that I hear with this power supply are nothing short of impressive. The sense of realism, ease, increased soundstage, lack of edginess, 3D imaging, tighter and more realistic bass all contribute to an overall global improvement that for such relatively small change in my system is hard to believe at times. The power supply to me is a "no brainer" as far as upgrades to your system. It has the ability to actually make the recordings sound different in a very good way. Hate to use an audiophile cliche especially in my first post but it can make you hear things "that you haven't heard before".
For point of reference I have made the following upgrades to the DAC:
1. Sampling frequency mod
2. Silver wire from the board to the caps and then to the coax out
3. Dueland 4.7 uF caps on the output
4. Caddock I/V resistors
5. Blackgate caps on the DAC chips
6. I mounted everything in a new chassis that I had from a chip amp project
7. Upgraded the RCA outputs to Audio Note OEM because I had them around
For point of reference the rest of my system consists of:
Modified DIY HiFi 300b amps; CCS for driver stage, paralleled driver tube, V-Cap coupling caps, Jack Elliano Partial Silver output transformers and power supply transformers, solid silver wiring and Mundorf M Tube caps in the power supply, etc.
26 tube preamp
D'Apollito Bastanis wideband drivers w/ subs
Flat silver speaker wire (DIY)
VH Audio solid silver DIY interconnects and power cable
Bastanis power cable
My listening is focused on Jazz and 60's through 90's rock. My priorities for my system are realistic dynamics, believable soundstage, proper tone and timbre and a lack of grain and harshness in the treble region as this seems to take away pleasure faster than anything else.
I would also like to take the time to thank all of the posters here for their time and efforts to keep the hobby close to it's roots, i.e. having fun listening to music.
Regards to all, Tony
