newbee123
- Jun 16, 2011
Any one can direct me to buy the 47uf Blackgate FK? been searching all over Ebay but no luck
tks
tks
tks
The original Sonicaps (5ufd) should be much better than Wimas and are smaller than most films. If you have a receiver/pre with caps on the input you should be able to just remove the output caps and bypass with a wire. I've done this and been very pleased with the results.
Does anyone have a (sensibly-priced) recommendation for output caps which will fit in the enclosure? Has anyone tried Wimas?
